Is possible change administrative distance in connected interface ?
lps05073
Is possible change administrative distance in connected interface (0) ?
I like change administrative distance of 0 to 10 or other.
ruwhite
Level 7
Level 7
Nope--you can change the admin distance on a static route, but not an interface.
Russ
Thank you.
perkin
Woo, this is a 18 years ago question, that is the question when I was young... good old day,
so assumed no one will response this thread.
allow me to assume this question, -- I assumed IPS05073 want to do some active/passive segment -- when production router services the IP range normally, then the backup router (the router itself) will even sending traffic to the production segment.  when the production router down, then it will send that back to local.
if I based on this assumption, then the most easiest way will be installing more specific route (no matter from static or routing protocol)
