Is there any compatibilty issue btw PA-T3 with NM-1T3/E3?
ganeshp
Tested on 7513 PA-T3 to connect to remote site via 7200 PA-T3 no issue. Line is up.
Tested on 7513 PA-T3 to connect to remote site via 3660 using NM-1T3/E3. AL Alarm. Line is down.
Below is my sample config 3660
card type t3 1
controller T3 1/0
interface Serial1/0
no ip address
no ip route-cache
dsu bandwidth 44210
Is there anything else need to be configured on the controller or serial interface? Or is there any compatibilty issue?
olorunloba
Level 5
Level 5
Try and check that the same linecode, framing and clocking are configured at both ends. I do not see why they should not work together.
