ISDN Connectivity problem
ddnicholls
I have a 2611 in a hub site, and another at a spoke site. The hub site router is acting as a simple access router with an E1 card transferring requests to a Radius server. This part works fine locally however when dialling up remotely, the hub router hangs the line up after a few seconds without even attempting to authenticate. Hub config is below, the spoke sited were dialling successfully to a Tigris router. Any help appreciated.
Dean
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname mel04
logging rate-limit console 10 except errors
aaa new-model
enable password 7 045E1B570C345E4B
ip subnet-zero
no ip finger
no ip domain-lookup
isdn switch-type primary-net5
--More-- !
controller E1 1/0
pri-group timeslots 1-31
interface Ethernet0/0
description Connected to HP Switch on mel04 VLAN
ip address 202.81.96.122 255.255.255.252
full-duplex
interface Ethernet0/1
no ip address
shutdown
half-duplex
interface Serial1/0:15
no ip address
isdn T310 30000
no cdp enable
interface Dialer0
no ip address
--More-- no cdp enable
interface Dialer1
description connected to dial in PCs(ISDN)
no ip address
encapsulation ppp
no ip split-horizon
dialer in-band
dialer-group 1
peer default ip address pool mel04-Group-1
ppp authentication chap pap callin
ppp multilink
router rip
version 2
network 202.81.96.0
no auto-summary
ip local pool me104-Group-1 203.81.106.1 203.81.106.30
ip classless
ip default-network 202.81.96.0
ip http server
--More-- snmp-server community public RO
snmp-server location Richmond
radius-server host 202.81.96.93 auth-port 1645 acct-port 1646 key 7 050C051B285F5E
radius-server host 202.81.96.94 auth-port 1645 acct-port 1646 key 7 10490A0D0C0402
radius-server host 202.81.96.99 auth-port 1645 acct-port 1646 key 7 07082258471A09
radius-server retransmit 3
line con 0
exec-timeout 0 0
password 7 11071C0E031319
transport input none
line aux 0
line vty 0 4
password 7 082F49451D1817
no scheduler allocate
end
xge
I think there is some configuration problem. You have to enable aaa authentication. You can refer to the URL to enable auth:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/secur_c/scprt1/scdathen.htm
Hope it helpful.
My apologies, I posted an old config, here is the correct one.
sh run
Building configuration...
Current configuration : 2183 bytes
version 12.1
hostname mel04
aaa new-model
aaa authentication login default group radius
aaa authentication login NO_RADIUS local
aaa authentication ppp default group radius
aaa authorization exec default group radius
aaa authorization exec NO_RADIUS local
aaa authorization network default local group radius
aaa accounting send stop-record authentication failure
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
--More-- !
username root password 7 151C0E07102B39
ip subnet-zero
no ip finger
no ip domain-lookup
ip name-server 202.81.96.82
isdn switch-type primary-ts014
controller E1 1/0
ip address 202.81.105.66 255.255.255.252
full-duplex
no ip address
--More-- shutdown
half-duplex
no ip address
no cdp enable
interface Dialer0
no ip address
no cdp enable
interface Dialer1
no ip address
encapsulation ppp
no ip split-horizon
dialer in-band
dialer-group 1
ppp multilink
--More-- ip local pool me104-Group-1 203.81.106.1 203.81.106.30
ip classless
ip default-network 202.81.105.0
ip route 0.0.0.0 0.0.0.0 202.81.105.65
ip http server
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password 7 06080A2A584F1B
--More-- authorization exec NO_RADIUS
login authentication NO_RADIUS
end
mel04#
you need to link the serial pri to the dialer int with a pool.
on serial int put:
dialer pool-member 1
on dialer int put:
dialer pool 1
This router is not performing any CHAP authentication, simply passing the information through to a Win2K Radius server. Does it still need dialer pools? I understood they were only required in the case of an access router, or do I need to set up authentication from the remote router to allow it to pass through to the Radius server, ie a user name for the remote router?
