ISDN dial in and out
velimirmkd
Beginner
Beginner
Is it possible to have simultanious dial in and dial out connection on the same ISDN BRI? I suppose there are some limitations with the signaling but would like to verify with the forum
Thks
Velimir
tepatel
BRI line has 2 B-channels and a D channel..so you can use one for dialin and another for dialout simultaneously...D channel is the one which will handle signalling part..
Thanks for your resopnse.
I searched all over Cisco's site and could not find any sample config on this problem. Do you have any suggestions?
Velimir
Hi Velimir
You can use dialer profile to configure this. You create two profiles one for dial out and one for dila-in.You may find many configurations of dialer profile on cisco website.
You can find more details on this link. This logical profile will carry out your in and out functionality.
http://www.cisco.com/warp/public/793/access_dial/ddr_dialer_profile.html
Dilip
Recognize Your Peers
