ISDN layer 2 not up
boonteongng
I am configuring a new AS5350 with 1 E1 PRI to accespt analog and ISDN calls. The E1 controller is up with no alarms. The corresponding serial 3/0:15 is also up, up (spoofing). However, when I show isdn status, the layer 2 is at TEI_ASSIGNED state. Debug isdn q921 shows that there is only outgoing control message but no incoming traqffic. I had changed the cable and E1 port. What could be the cause ?
thanks for the help.
6 Replies 6
Kevin Dorrell
Level 10
Level 10
I presume "show isdn status" says the physical layer is ACTIVE?
I would expect the state of the Layer 2 to be "MULTIPLE_FRAME_ESTABLISHED". I you haven't got that, you can ignore the state of S3/0:15. I would have a word with your telecom provider (or switchboard support techie) and see if they have activated the line.
Kevin Dorrell,
Luxembourg
Yes, the physical layer is active.
The line is activated as if I plug it in a existing non-cisco RAS, I can dial in to the same phone number.
What is the ISDN switch type? Is that configured correctly?
Kevin
ISDN switch type is primary-net3
Linecode hdb8
framing crc
If I try to change to other switch type, it will bring down the E1 controller.
Upgrade the IOS! I faced the same issue with CT1 to terminate ISDN PRI in Japan.
I can see packets going out from the CT1 interface while doing debug q921 but none from telecom switch. L2 Status also same as u said (TEI Assigned).
The platform I used was 3662 with IOS 12.1 main train.
I replaced the module but no change finally I upgraded IOS to some 12.2T, it solved my problem.
Hope that helps!
Subba
thanks Subba.
The problem is resolved. It was a wrong patching to the user interface at the telco end instead of network interface.
thanks for all the suggestions.
