ISDN ppp callback not works with multilink !?
KAROLY KOHEGYI
Level 2
Level 2
Hi!
We use a CISCO 5350 for dial-in and dial-out functons.
The ppp ISDN and ppp analog dial-in work with single-line or ppp multink.
The ISDN PPP callback works on single-line.
When i try the multilink capability the NAS callback single-line only.
The debug isdn q931 shows one isdn call only.
Why does not NAS try the open the secondary ISDN channel??
Here is the config.
version 12.2
service exec-callback
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname ispw3
no boot startup-test
logging buffered 65000 debugging
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication ppp default local group tacacs+
aaa authentication ppp elektra if-needed group tacacs+
aaa authorization exec default group tacacs+ none
aaa authorization network default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
enable password 7 <removed>
username admin password 7 <removed>
username manager password 7 <removed>
resource-pool disable
clock timezone MET 1
spe country e1-default
ip subnet-zero
ip cef
no ip ftp passive
ip domain-name net1.mkb.hu
ip name-server 172.18.1.3
ip name-server 172.18.1.8
ip ssh time-out 120
ip ssh authentication-retries 3
ip address-pool local
multilink virtual-template 1
virtual-profile virtual-template 1
virtual-profile aaa
isdn switch-type primary-net5
isdn voice-call-failure 0
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 60 CONNECT \c
chat-script aux ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 60 CONNECT \c
chat-script offhook "" "ATH1" OK
chat-script callbackuj ABORT ERROR ABORT BUSY "" "ATZ" OK "ATS29=5" OK "ATDT \T" TIMEOUT 60 CONNECT \c
modemcap entry nextport miscellaneous ats29=5
modemcap entry MKB:FD=&F:MSC=s29=6
fax interface-type fax-mail
mta receive maximum-recipients 0
crypto mib ipsec flowmib history tunnel size 200
crypto mib ipsec flowmib history failure size 200
controller E1 3/0
pri-group timeslots 1-31
controller E1 3/1
controller E1 3/2
controller E1 3/3
controller E1 3/4
controller E1 3/5
controller E1 3/6
controller E1 3/7
interface FastEthernet0/0
ip address 172.18.1.16 255.255.0.0
no ip route-cache
no ip mroute-cache
no keepalive
duplex full
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clockrate 2000000
interface Serial0/1
no ip address
shutdown
clockrate 2000000
interface Serial3/0:15
ip unnumbered FastEthernet0/0
encapsulation ppp
no ip route-cache
load-interval 30
dialer idle-timeout 600
dialer load-threshold 1 either
dialer-group 1
autodetect encapsulation ppp v120 lapb-ta
isdn incoming-voice modem
isdn calling-number 8530
isdn outgoing-voice info-transfer-capability 3.1kHz-audio
no fair-queue
no cdp enable
ppp callback accept
ppp authentication ms-chap chap pap elektra
ppp multilink
interface Virtual-Template1
description **** Analog userek *****
no ip route-cache
ip tcp header-compression
load-interval 30
no keepalive
ppp callback accept
ppp multilink
ppp timeout retry 5
multilink load-threshold 1 either
interface Group-Async0
encapsulation ppp
no ip route-cache
no ip mroute-cache
async mode interactive
no fair-queue
ppp callback accept
ppp timeout retry 5
group-range 1/00 1/107
ip classless
ip route 0.0.0.0 0.0.0.0 172.18.1.2
no ip http server
ip access-list extended cardinal-ppp
permit tcp any host 172.18.1.9 eq telnet
permit udp any host 172.18.1.3 eq domain
permit tcp any host 172.18.1.10 eq telnet
ip access-list extended elektra-ppp
permit tcp any host 172.18.1.9 eq 7003
ip access-list extended hobo-in
permit tcp any host 172.18.1.2 eq 6660
logging 172.18.1.15
dialer-list 1 protocol ip permit
no cdp run
tacacs-server host 172.18.1.6 single-connection
tacacs-server host 172.18.1.15 single-connection
tacacs-server key <removed>
snmp-server community <removed> RO
snmp-server enable traps tty
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps envmon
snmp-server enable traps bgp
snmp-server enable traps rsvp
snmp-server enable traps frame-relay
snmp-server enable traps rtr
snmp-server enable traps syslog
call rsvp-sync
voice-port 3/0:D
compand-type a-law
mgcp profile default
dial-peer cor custom
banner motd ^CCC
ACCESS-SERVER CISCO 5350
User Access Verification
^C
line con 0
exec-timeout 0 0
stopbits 1
flowcontrol software
line aux 0
script modem-off-hook offhook
script callback aux
modem answer-timeout 5
modem InOut
transport input all
escape-character NONE
autoselect ppp
callback forced-wait 10
stopbits 1
speed 19200
line vty 0 4
exec-timeout 0 0
line vty 5 15
line 1/00 1/107
session-timeout 60
no exec-banner
exec-timeout 30 0
timeout login response 60
no flush-at-activation
no activation-character
script callback callbackuj
modem InOut
modem autoconfigure type MKB
transport input all
autoselect during-login
autoselect ppp
scheduler allocate 10000 400
end
5 Replies 5
mljohnson
Level 4
Level 4
It's difficult to say without debug; in particular, "debug ppp neg", "debug callback", "debug isdn q931", "debug aaa authen", and "debug aaa author". This debug should indicate what the problem is in calling back a second time.
KAROLY KOHEGYI
Level 2
Level 2
Hi!
Here is the debug output what you asked. i set the 'debug ppp multilink event' too which show the traffic is above the threshold on the interface. Nov 15 10:20:51.995: ISDN Se3/0:15: RX <- SETUP pd = 8 callref = 0x5D5F Nov 15 10:20:51.995: Sending Complete Nov 15 10:20:51.995: Bearer Capability i = 0x8890 Nov 15 10:20:51.995: Channel ID i = 0xA18394 Nov 15 10:20:51.995: Calling Party Number i = 'A', 0x83, '4672060', Plan:ISDN, Type:Subscriber(local) Nov 15 10:20:51.995: Called Party Number i = 0xC9, '8520', Plan:Private, Type:Subscriber(local) Nov 15 10:20:51.999: AAA/ACCT/DS0: channel=19, ds1=0, t3=0, slot=3, ds0=50331667 Nov 15 10:20:51.999: AAA/ACCT/DS0: channel=19, ds1=0, t3=0, slot=3, ds0=50331667 Nov 15 10:20:51.999: ISDN Se3/0:15: TX -> CALL_PROC pd = 8 callref = 0xDD5F Nov 15 10:20:51.999: Channel ID i = 0xA98394 Nov 15 10:20:51.999: ISDN Se3/0:15: TX -> CONNECT pd = 8 callref = 0xDD5F Nov 15 10:20:51.999: Channel ID i = 0xA98394 Nov 15 10:20:52.019: ISDN Se3/0:15: RX <- CONNECT_ACK pd = 8 callref = 0x5D5F Nov 15 10:20:52.019: ISDN Se3/0:15: CALL_PROGRESS: CALL_CONNECTED call id 0xC8, bchan 19, dsl 0 Nov 15 10:20:52.431: Se3/0:19 PPP: Treating connection as a callin Nov 15 10:20:52.431: Se3/0:19 PPP: Phase is ESTABLISHING, Passive Open Nov 15 10:20:52.431: Se3/0:19 LCP: State is Listen Nov 15 10:20:52.431: Se3/0:19 LCP: I CONFREQ [Listen] id 1 len 27 Nov 15 10:20:52.431: Se3/0:19 LCP: MRU 1500 (0x010405DC) Nov 15 10:20:52.431: Se3/0:19 LCP: MagicNumber 0x18F44247 (0x050618F44247) Nov 15 10:20:52.431: Se3/0:19 LCP: Callback 6 (0x0D0306) Nov 15 10:20:52.431: Se3/0:19 LCP: MRRU 1500 (0x110405DC) Nov 15 10:20:52.435: Se3/0:19 LCP: EndpointDisc 1 Local (0x130601194F02) Nov 15 10:20:52.435: Se3/0:19 LCP: O CONFREQ [Listen] id 3 len 27 Nov 15 10:20:52.435: Se3/0:19 LCP: AuthProto MS-CHAP (0x0305C22380) Nov 15 10:20:52.435: Se3/0:19 LCP: MagicNumber 0x1FB32031 (0x05061FB32031) Nov 15 10:20:52.435: Se3/0:19 LCP: MRRU 1524 (0x110405F4) Nov 15 10:20:52.435: Se3/0:19 LCP: EndpointDisc 1 ispw3 (0x1308016973707733) Nov 15 10:20:52.435: Se3/0:19 LCP: O CONFACK [Listen] id 1 len 27 Nov 15 10:20:52.435: Se3/0:19 LCP: MRU 1500 (0x010405DC) Nov 15 10:20:52.435: Se3/0:19 LCP: MagicNumber 0x18F44247 (0x050618F44247) Nov 15 10:20:52.435: Se3/0:19 LCP: Callback 6 (0x0D0306) Nov 15 10:20:52.435: Se3/0:19 LCP: MRRU 1500 (0x110405DC) Nov 15 10:20:52.435: Se3/0:19 LCP: EndpointDisc 1 Local (0x130601194F02) Nov 15 10:20:52.447: Se3/0:19 LCP: I CONFNAK [ACKsent] id 3 len 8 Nov 15 10:20:52.447: Se3/0:19 LCP: AuthProto PAP (0x0304C023) Nov 15 10:20:52.447: Se3/0:19 LCP: O CONFREQ [ACKsent] id 4 len 26 Nov 15 10:20:52.447: Se3/0:19 LCP: AuthProto PAP (0x0304C023) Nov 15 10:20:52.447: Se3/0:19 LCP: MagicNumber 0x1FB32031 (0x05061FB32031) Nov 15 10:20:52.447: Se3/0:19 LCP: MRRU 1524 (0x110405F4) Nov 15 10:20:52.451: Se3/0:19 LCP: EndpointDisc 1 ispw3 (0x1308016973707733) Nov 15 10:20:52.479: Se3/0:19 LCP: I CONFACK [ACKsent] id 4 len 26 Nov 15 10:20:52.479: Se3/0:19 LCP: AuthProto PAP (0x0304C023) Nov 15 10:20:52.479: Se3/0:19 LCP: MagicNumber 0x1FB32031 (0x05061FB32031) Nov 15 10:20:52.479: Se3/0:19 LCP: MRRU 1524 (0x110405F4) Nov 15 10:20:52.479: Se3/0:19 LCP: EndpointDisc 1 ispw3 (0x1308016973707733) Nov 15 10:20:52.479: Se3/0:19 LCP: State is Open Nov 15 10:20:52.479: Se3/0:19 PPP: Phase is AUTHENTICATING, by this end Nov 15 10:20:52.483: Se3/0:19 LCP: I IDENTIFY [Open] id 2 len 18 magic 0x18F44247 MSRASV5.00 Nov 15 10:20:52.483: Se3/0:19 LCP: I IDENTIFY [Open] id 3 len 20 magic 0x18F44247 MSRAS-1-KOKI Nov 15 10:20:52.487: Se3/0:19 PAP: I AUTH-REQ id 17 len 23 from "kakohegyi" Nov 15 10:20:52.487: Se3/0:19 PAP: Authenticating peer kakohegyi Nov 15 10:20:52.487: Se3/0:19 PPP: Phase is FORWARDING, Attempting Forward Nov 15 10:20:52.487: Se3/0:19 PPP: Phase is AUTHENTICATING, Unauthenticated User Nov 15 10:20:52.491: AAA/AUTHEN/PPP (0000005A): Pick method list 'elektra' Nov 15 10:20:52.995: Se3/0:19 PPP: Phase is FORWARDING, Attempting Forw
mljohnson
Level 4
Level 4
You have a load-threshold configured on the serial interface, but no dialer map. If you want to use MPPP BOD for the remotes, it would be best to have the remotes initiate a second call (configure a dialer load-threshold on them); otherwise, you will need to configure a static dialer map for each remote that should be called back a second time. And with a dialer map, you would need to configure a "class" option with it to authorize callback in the first place.
Hi!
Yes. I see this solution in many examples.
But we have got many of users. It is not possible to make many-many STATIC Dialer map.
I would like that NAS initiates the second call immediately ( or later ) by AAA information ( DIALER STRING, USERNAME )
IS IT POSSIBLE OR I'LL FORGET THIS POSSIBILITY?
ps.
Unfortunetly my ISDN ( Zyxel omni.net plus ) TA does not make a second call after callback. The client ppp Mppp works dial-in only.
The dialer maps are not required if you have the remotes initiate the second call; this only requires the addition of the "dialer load-threshold" command on the remotes, if using cisco's.
If you want the NAS to intitiate the second call, you need the static dialer maps. You could have a look at Large Scale Dialout (this would elimiate the need for a map), although I'm not sure that this would work given that the first connection would not be brought up using LSDO.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_c/fnsprt11/dafsdil.htm
Having the remote's initiate both the first and second call would likely be the easiest to maintain. I'm not familiar with the oomni.net, but if it supports MPPP and dialout it should support the dialing of a second link.
