Issues with Hotspot 1.0
ganeshp
I'm using Hotspot 1.0 bulid 1. My clients are connected via wireless network. AP are connected to switch and the switch to the Hotspot.
Now I'm having few issues:
1) What is the mechanism for timing out clients which is connected to the AP?
2) One of the customer is using PDA and only the first time authentication process took place. After then each time my client can get thru the site without any authentication. Is this cause there is no proper disconnect windows for PDA session?
3) There will be frequent pop up menu on hotspot -"memory error - svchost.exe". We need to reboot the server for the hotspot to function again. Is this a bug?
regards,
Ganesh
amritpatek
Level 6
Level 6
You may want to refer to the release notes section of the following URL. It mentions about a few vulnerabilities in Hotspot 1.0. Check out :
Cisco Building Broadband Service Manager BBSM Hotspot Server Version 1.0
http://www.cisco.com/en/US/products/sw/netmgtsw/ps533/ps4950/index.html
