LACP lab doesn't works properly
write2irfan
I am preparing lab for CCNP Switch exam.
If I trace the packet , i found that ARP messages are passing from SwitchA to Switch B , but from SwitchB to SwitchA doesnt passes.
Host in SwitchB is no getting access to DHCP at router connected to SwitchA f0/1
SwitchB
show etherchannel summary
1      Po1(SU)           LACP   Fa0/3(P) Fa0/4(P) Po1(I)
SwitchA
below is my configuration
SwitchA
vtp domain DOMAIN
vtp mode transparent
spanning-tree mode rapid-pvst
spanning-tree vlan 11-13,21-23 priority 8192
vlan 11
vlan 12
vlan 13
vlan 21
name Marketing
vlan 22
name Sales
vlan 23
name Engineering
vlan 99
name TrunkNative
interface FastEthernet0/1 (connected with router )
switchport mode trunk
interface FastEthernet0/2 ( connected to a server which can get ip through DHCP in router)
switchport access vlan 21
switchport mode access
interface FastEthernet0/3
switchport trunk native vlan 99
switchport trunk allowed vlan 1,21-23,99
channel-protocol lacp
channel-group 1 mode active
interface FastEthernet0/4
interface Port-channel 1
interface Vlan1
no ip address
SwitchB
vtp domain DOMAIN
vlan 21
name Marketing
vlan 22
name Sales
vlan 23
name Engineering
vlan 99
name TrunkNative
channel-group 1 mode passive
interface FastEthernet0/9
spanning-tree portfast
interface FastEthernet0/10
interface FastEthernet0/13
switchport access vlan 22
interface FastEthernet0/14
interface FastEthernet0/15
switchport access vlan 23
interface FastEthernet0/16
interface Vlan1
ip address 192.168.1.11 255.255.255.0
ip default-gateway 192.168.1.1
kcnajaf
Level 7
Level 7
Hi Irfan,
It looks like you have a wrong configuration on SwitchB. You dont put the channel group command under the actual port-channel interface itself. So please modify the configuraton as below and test the result for DHCP.
SwitchB
config terminal
no channel-group 1 mode passive
exit
Hope that helps
Najaf
Please rate when applicable or helpful !!!
kcnajaf
Level 7
Level 7
Hi Irfan,
SwitchB
config terminal
exit
Hope that helps
Najaf
Dear Najaf,
Great finding, IDHCP is working fine. Now i have a question Why LAB says make Switch B Interface port-cha 1 passive ?
Hi Irfan,
If the Lab says that you to make interface as passive then this configuration has to be applied on the physcial interface and not on the port-channel interface, which would then be applied to the actual port-channel interface.
Hope that helps.
Najaf
