Length of Console Cable
kpatoli
How long a console cable can be extended?
amritpatek
Level 6
Level 6
As far as I know, there is no length limitation for console cable.
bjellig
The length of a serial console cable is impacted by the type of cable used (low capacitance = longer lengths), and the data transmission speed (higher speeds = shorter cables).
I've run cat5 serial cables ~400 feet at 9600 baud, but at 19200, I've had problems running over 50 feet at times.
