Load Balance and QOS
gjohnson1963
I am in the process of ordering a second full T1. I would like to load balance the traffic on the two wan ports. I also would like to implement some QOS for one of my web sites. We have a 1720 router will this router be able to handle this, or will I need a higher end router?
ankurbhasin
Level 9
Level 9
Hi 1721 support QOS but again 1721 is a small end router used for remote office and it depends how complex your QOS policies are and what load exactly you are putting on your 1721.
But yes 1721 supports QOS.
abraham_pe
tu tienes que balancear la carga con el comando
no ip route-cache no ip mroute-cache, y ell QOS lo haces con los Priority-list High, Medium,Flow
