11-05-2002 05:58 PM - edited 03-02-2019 02:40 AM
I have 2 router 3640 and it have 3 pvc
256K for voice
256K for Data
512K for Video
I use Frame Relay, but went i don´t have videoconference i want to use the pvc of 256K Data + 512K video only both for data, The bandwith of each PVC is setting in the sub interface and i use 3 definition of eigrp one for service. i was probe with only 2 definition of eigrp and apply the variance command , but went i use a traceroute of 1 pc in every site only use one path, in the router the tracer use the 2 path
This is part of the router configuration for use the data and video PVC
router eigrp 1
variance 2
network 10.0.5.0 0.0.0.255
network 10.0.105.0 0.0.0.255
network 192.168.2.40 0.0.0.3
network 192.168.4.40 0.0.0.3
maximum-paths 2
no auto-summary
no eigrp log-neighbor-changes
interface Serial0/0.44 point-to-point
description Data 256Kbps
bandwidth 256
ip address 192.168.3.42 255.255.255.252
no ip mroute-cache
frame-relay interface-dlci 44
class voz-256k
interface Serial0/0.45 point-to-point
description Video a 512Kbps
bandwidth 512
ip address 192.168.4.42 255.255.255.252
no ip mroute-cache
frame-relay interface-dlci 45
class video-512k
and part of information #sho ip route 10.0.10.0
Routing entry for 10.0.10.0/24
Known via "eigrp 1", distance 90, metric 5537536, type internal
Redistributing via eigrp 1
Last update from 192.168.4.41 on Serial0/0.45, 01:57:40 ago
Routing Descriptor Blocks:
192.168.2.41, from 192.168.2.41, 01:57:40 ago, via Serial0/0.43
Route metric is 10537472, traffic share count is 1
Total delay is 21000 microseconds, minimum bandwidth is 256 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
* 192.168.4.41, from 192.168.4.41, 01:57:40 ago, via Serial0/0.45
Route metric is 5537536, traffic share count is 2
Total delay is 21000 microseconds, minimum bandwidth is 512 Kbit
of route
Perphas
I was use mrtg to measure the bandwith and the balance of the it is not proportional 2:1
How i can to verify if the balance is o.k
11-05-2002 08:14 PM
Try turning of Fast switching, and check the traceroute from the PC. From the PCwhen you do a tracert, the packets are fast switched, and it wil use only one path, because, per destination Load balancing is configure
11-12-2002 10:06 AM
To turn off Fast switching, you can use " no ip route-cache" under each subinterface.
