Making a simple LAN using IPv6
omarmontes
Hi guys, looking for help again, here is the deal:
I'm trying to make a little LAN (2 or more computers with windows XP and 2000 and a Hub or Switch, no Router involved) using IPv6.
I have already installed IPv6 stack on all the computers and configured an IPv6 address on the hosts, but I can't get ping6 responses between them. I guess I have to configure a default gateway or similar for IPv6.
Thanks in advance!
erhoehne
You should make sure that you have your interfaces on each computer on the same network and double check your netmask on both interfaces. Pings should work if the above is correct. Good luck!
