Max number of (IGP) EIGRP processes
f.Medat
How many EIGRP processes can a MSFC2 supports sumultaneously ?
I didn't find any written doc about that?
Thanks in advance
Best Regards
Fabien.
ruwhite
Level 7
Level 7
You can have up to 32 processes on a cisco router. 1 is used for static routes, another is used for connected routes, and the other 30 can be dynamic routing processes.
Russ
gaston.benitez
Hi.
Please take into account that for some IOS/Platforms the limit compreheds the sum of all the routing protocols. So, if you have 1 BGP and 4 OSPF processes, your real limit will be 25 EIGRP processes in total.
I have made an example in this post.
https://community.cisco.com/t5/routing/too-many-ip-routing-processes/m-p/3748666/highlight/false#M304891
BR
Gaston
