Maximum MTU size on Fastethernet interface.
raju
We have a RAS server (3745) with E1 line and the Fastethernet 0/0 is connected with Internal LAN .When dial-in user's increases more than 20 (concurrent), RAS server start sending syslog messages that MTU size on Fastethernet 0/0 exceeded . Can I increase the MTU size on Fastethernet interface and if so , What is the maximum size FE supports and since I want to try with maximum value?.
thisisshanky
Level 11
Level 11
Can you paste the Syslog message ? The max size on FE should be no more than 1500 bytes and thats the default value!! You can only set to something less than 1500.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
