Maximum number of switches between two endpoints ?
marcelscheller
I know there's a limit concerning the number of switches between two endpoints used in a STP enviroment, but is there a "Cisco" document describing this issue ?
Marcel
Milan,
Thanks for the documents !
Marcel
bbranch
Level 3
Level 3
Or you can check out the IEEE 802.1d & 802.1w specs, these state that the maximum diameter (The maximum bridge diameter of the Bridge LAN: The maximum number of Bridges between
any two points of attachment of end stations) as 7:
802.1d - Section 8.10.2
http://standards.ieee.org/getieee802/download/802.1D-1998.pdf
802.1w - Section 17.28.2
http://standards.ieee.org/getieee802/download/802.1w-2001.pdf
