12-13-2004 08:28 AM - edited 03-02-2019 08:33 PM
We have a 6509 that shows the following problem.Can anyone help?
Dec 13 5:28:08: %SYSTEM_CONTROLLER-3-MORE_COR_ERR: 2 correctable DRAM memory errors in previous hour
Dec 13 5:28:08: %SYSTEM_CONTROLLER-3-COR_MEM_ERR: Correctable DRAM memory error. Count 0, log 805CACB8
Its IOS version is
IOS (tm) c6sup2_rp Software (c6sup2_rp-JK2S-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Thanks a lot.
Solved! Go to Solution.
12-13-2004 08:38 AM
Try reseating DRAM on the MSFC. If you still see errors, you'll need to get the Sup/DRAM replaced.
12-13-2004 08:38 AM
