Multicast Interface Configuration (igmp and dr)
kfarrington
Level 3
Level 3
I would like some advice please on what the above should be set for.
I plan to roll pim-sparse-dense mode out over a large corporate network in London using Auto-RP very soon, and I plan to set the PIM DR manually to the HSRP active interface so that we can have unicase and multicast active on the same interface.
I am also going to set the ip pim query-interval to the same values as out HSRP values.
A typical config would be for a lan with two routers is :-
interface Vlan573
description Server Farm
ip address 40.253.73.251 255.255.255.0
ip pim sparse-dense
ip pim dr priority 110
ip pim query-interval 2
standby timers 2 6
standby priority 110 preempt
standby ip 30.253.73.253
Should I also change the IGMP timers to co-inside with the HSRP and PIM DR timers ?
ip igmp query-timeout <value>
ip igmp query-interval <value>
Many thx indeed,
Ken
kfarrington
Level 3
Level 3
sorry, forgot the second router config, here they are again
router1
interface Vlan573
ip pim sparse-dense
standby timers 2 6
router2
interface Vlan573
ip address 40.253.73.252 255.255.255.0
ip pim sparse-dense
ip pim dr priority 100
standby timers 2 6
standby priority 100 preempt
