Multicasting - Ghost Multicast Server Problems
sregner
Community Member
I know that this topic has appeared in these forums before because I have already looked through most of the answers for direction. I am still stuck so I am posting this question. Is there any limitation in the 6500 series Sup 1A mod that prevents more then 12-15 multicast clients from joining at any one time.
We have used two products for lab management in the past. Alteris RapidDeploy and Ghost. We are currently moving to ghost as the product of choice. This brings some problems. We just started using multicast. with the alteris we are able to multicast to 60+ machines at a time but with ghost we have problems.
We use a 6506 with a Sup 1A as the core of our network and have a mixture of Cisco 2950's and 3Com 1100's and 3300 in remote buildings. Buildings are connected with 100Meg Fiber. We are behind on our software updates for our 6506 (currently CatOS 5.5(1) and IOS12.1(2)E ED) I have enable multicast on the router, set the interfaces to pim-sparse-dense mode and created a set RP. (suggest in another article) IGMP is enabled on the switch and the switch is aware what ports are multicast enabled.
We are stuck because it seems that no matter what we do, there seems to be a limit that we hit. Given time we can get about 18 machines to join a group but we have never gotten more then that.
Is the problem with our sup module? software level? configuration? I you would like I can post the configs of our 6506 but I have read several CIsco articles and I think I have enable at least the basic multicast commands.
Any help/suggestions would be greatly appreciated
Matt Regner
Network Support Specialist
5 Replies 5
dathaide
Level 4
Level 4
hi
so you say you can get only 18 machines to join the group. What happens when the 18th person leaves the group does another machine join?
Have you pretty much narrowed it down to the equipment and not the Pc's because some NIC drivers in PC does not support multicast very well. Also are you running rgmp on your interface? Can you send me your basic config if possible
thanks
sregner
Community Member
If you reboot machines in the group, other machine that were not part of the group join in. I have rgmp enabled but I didn't do anything to configure any of the individual interfaces. Unlike the multicast router were multicast routing was turn on each interface I know it is not good form but if you change the mode while some machines are in the group and the others are waiting then they will all join. i.e change the mode on the interface from ip pim sparse-dense-mode to ip pim sparse-mode will make them join for that session but not for the next session. When the ghost task starts, any machines that were waiting will then join a group but not the group already in the task. This weekend we are taking both portions to their latest software levels.
Thanks for any insights
Posting Both Configs, Sorry for the long post.
router config (session 15)
Current configuration:
version 12.1
service timestamps debug datetime
service timestamps log datetime
hostname Kings-Rtr
boot system bootflash:c6msfc2-is-mz.121-2.E
boot bootldr bootflash:c6msfc2-boot-mz.121-2.E
no logging console
ip subnet-zero
ip cef
no ip domain-lookup
ip name-server 10.1.18.56
ip name-server 10.1.18.55
ip multicast-routing
interface Loopback0
ip address 10.1.2.2 255.255.255.0
interface Vlan1
ip address 10.1.1.2 255.255.255.0
no ip mroute-cache
interface Vlan2
no ip address
shutdown
interface Vlan12
no ip address
ip helper-address 10.1.18.170
shutdown
interface Vlan13
ip address 10.1.13.1 255.255.255.0
ip helper-address 10.1.18.56
ip helper-address 10.1.25.25
ip pim sparse-mode
interface Vlan14
ip address 10.1.14.1 255.255.255.0
interface Vlan15
ip address 10.1.15.1 255.255.255.0
interface Vlan16
ip address 10.1.16.1 255.255.255.0
interface Vlan17
ip address 10.1.17.1 255.255.255.0
interface Vlan18
ip address 10.1.18.1 255.255.255.0
interface Vlan19
ip address 10.1.19.1 255.255.255.0
interface Vlan20
ip address 10.1.20.1 255.255.255.0
ip helper-address 10.1.18.111
interface Vlan21
ip address 10.1.21.1 255.255.255.0
interface Vlan22
ip address 10.1.22.1 255.255.255.0
interface Vlan23
ip address 10.1.23.1 255.255.255.0
interface Vlan24
no ip address
interface Vlan25
ip address 10.1.25.1 255.255.255.0
interface Vlan101
ip address 10.1.101.1 255.255.255.0
interface Vlan102
ip address 10.1.102.1 255.255.255.0
interface Vlan103
ip address 10.1.103.1 255.255.255.0
interface Vlan104
ip address 10.1.104.1 255.255.255.0
interface Vlan105
ip address 10.1.105.1 255.255.255.0
interface Vlan106
ip address 10.1.106.1 255.255.255.0
interface Vlan107
ip address 10.1.107.1 255.255.255.0
interface Vlan108
ip address 10.1.108.1 255.255.255.0
interface Vlan109
ip address 10.1.109.1 255.255.255.0
interface Vlan110
ip address 10.1.110.1 255.255.255.0
interface Vlan111
ip address 10.1.111.1 255.255.255.0
interface Vlan112
ip address 10.1.112.1 255.255.255.0
interface Vlan113
ip address 10.1.113.1 255.255.255.0
interface Vlan114
ip address 10.1.114.1 255.255.255.0
interface Vlan115
ip address 10.1.115.1 255.255.255.0
interface Vlan116
ip address 10.1.116.1 255.255.255.0
interface Vlan117
ip address 10.1.117.1 255.255.255.0
interface Vlan118
ip address 10.1.118.1 255.255.255.0
interface Vlan119
ip address 10.1.119.1 255.255.255.0
interface Vlan120
ip address 10.1.120.1 255.255.255.0
interface Vlan121
ip address 10.1.121.1 255.255.255.0
interface Vlan122
ip address 10.1.122.1 255.255.255.0
interface Vlan123
ip address 10.1.123.1 255.255.255.0
interface Vlan124
ip address 10.1.124.1 255.255.255.0
interface Vlan125
ip address 10.1.125.1 255.255.255.0
interface Vlan126
ip address 10.1.126.1 255.255.255.0
interface Vlan127
ip address 10.1.127.1 255.255.255.0
shutdown
interface Vlan128
ip address 10.1.128.1 255.255.255.0
interface Vlan129
ip address 10.1.129.1 255.255.255.0
router eigrp 1
network 10.1.0.0 0.0.255.255
ip default-gateway 10.1.18.19
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp time
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 10.1.18.19
ip http server
ip pim rp-address 10.1.2.2
ip pim send-rp-announce Loopback0 scope 16
ip pim send-rp-discovery scope 16
route-map Epix permit 10
set ip default next-hop 10.1.18.19
snmp-server engineID local 000000090200000021000000
snmp-server community rmeister RO
snmp-server community wmeister RW
snmp-server enable traps snmp
snmp-server enable traps rtr
snmp-server host 10.1.1.100 wmeister
end
Switch Configuration
This command shows non-default configurations only.
Use 'show config all' to show both default and non-default configurations.
begin
# ***** NON-DEFAULT CONFIGURATION *****
#time: Fri Feb 28 2003, 17:31:45
#version 5.5(1)
set password
set enablepass
#snmp
set snmp community read-only rmeister
set snmp community read-write wmeister
#vtp
set vtp domain kings
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 13 name VLAN0013 type ethernet mtu 1500 said 100013 state active
set vlan 14 name VLAN0014 type ethernet mtu 1500 said 100014 state active
set vlan 15 name VLAN0015 type ethernet mtu 1500 said 100015 state active
set vlan 16 name VLAN0016 type ethernet mtu 1500 said 100016 state active
set vlan 17 name VLAN0017 type ethernet mtu 1500 said 100017 state active
set vlan 18 name VLAN0018 type ethernet mtu 1500 said 100018 state active
set vlan 19 name VLAN0019 type ethernet mtu 1500 said 100019 state active
set vlan 20 name VLAN0020 type ethernet mtu 1500 said 100020 state active
set vlan 21 name VLAN0021 type ethernet mtu 1500 said 100021 state active
set vlan 22 name VLAN0022 type ethernet mtu 1500 said 100022 state active
set vlan 23 name VLAN0023 type ethernet mtu 1500 said 100023 state active
set vlan 24 name VLAN0024 type ethernet mtu 1500 said 100024 state active
set vlan 25 name VLAN0025 type ethernet mtu 1500 said 100025 state active
set vlan 101 name VLAN0101 type ethernet mtu 1500 said 100101 state active
set vlan 102 name VLAN0102 type ethernet mtu 1500 said 100102 state active
set vlan 103 name VLAN0103 type ethernet mtu 1500 said 100103 state active
set vlan 104 name VLAN0104 type ethernet mtu 1500 said 100104 state active
set vlan 105 name VLAN0105 type ethernet mtu 1500 said 100105 state active
set vlan 106 name VLAN0106 type ethernet mtu 1500 said 100106 state active
set vlan 107 name VLAN0107 type ethernet mtu 1500 said 100107 state active
set vlan 108 name VLAN0108 type ethernet mtu 1500 said 100108 state active
set vlan 109 name VLAN0109 type ethernet mtu 1500 said 100109 state active
set vlan 110 name VLAN0110 type ethernet mtu 1500 said 100110 state active
set vlan 111 name VLAN0111 type ethernet mtu 1500 said 100111 state active
set vlan 112 name VLAN0112 type ethernet mtu 1500 said 100112 state active
set vlan 113 name VLAN0113 type ethernet mtu 1500 said 100113 state active
set vlan 114 name VLAN0114 type ethernet mtu 1500 said 100114 state active
set vlan 115 name VLAN0115 type ethernet mtu 1500 said 100115 state active
set vlan 116 name VLAN0116 type ethernet mtu 1500 said 100116 state active
set vlan 117 name VLAN0117 type ethernet mtu 1500 said 100117 state active
set vlan 118 name VLAN0118 type ethernet mtu 1500 said 100118 state active
set vlan 119 name VLAN0119 type ethernet mtu 1500 said 100119 state active
set vlan 120 name VLAN0120 type ethernet mtu 1500 said 100120 state active
set vlan 121 name VLAN0121 type ethernet mtu 1500 said 100121 state active
set vlan 122 name VLAN0122 type ethernet mtu 1500 said 100122 state active
set vlan 123 name VLAN0123 type ethernet mtu 1500 said 100123 state active
set vlan 124 name VLAN0124 type ethernet mtu 1500 said 100124 state active
set vlan 125 name VLAN0125 type ethernet mtu 1500 said 100125 state active
set vlan 126 name VLAN0126 type ethernet mtu 1500 said 100126 state active
set vlan 127 name VLAN0127 type ethernet mtu 1500 said 100127 state active
set vlan 128 name VLAN0128 type ethernet mtu 1500 said 100128 state active
set vlan 129 name VLAN0129 type ethernet mtu 1500 said 100129 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active stp ibm
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state active mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sc0 1 10.1.1.1/255.255.255.0 10.1.1.255
set ip route 0.0.0.0/0.0.0.0 10.1.1.100
#set boot command
set boot config-register 0x2
set boot system flash bootflash:cat6000-sup.5-5-1.bin
#igmp
set igmp enable
#rgmp
set rgmp enable
#port channel
set port channel 3/1-4 2
set port channel 3/5-8 3
set port channel 3/9-12 4
set port channel 3/13-16 5
set port channel 3/17-20 6
set port channel 3/21-22 7
set port channel 4/1-4 8
set port channel 4/5-8 9
set port channel 4/9-12 10
set port channel 4/13-16 11
set port channel 4/17-20 12
set port channel 4/21-24 13
set port channel 6/1-4 14
set port channel 6/5-8 15
set port channel 6/9-12 16
set port channel 6/13-16 17
set port channel 6/17-20 18
set port channel 6/21-24 19
set port channel 6/25-28 20
set port channel 6/29-32,6/37-38 21
set port channel 6/33-36 22
set port channel 6/39-40 23
set port channel 6/41-44 24
set port channel 6/45-48 25
set port channel 3/23-24 100
# default port status is enable
#module 1 : 2-port 1000BaseX Supervisor
#module 2 empty
#module 3 : 24-port 100BaseFX MM Ethernet
set vlan 18 3/23-24
set vlan 101 3/1
set vlan 102 3/2
set vlan 103 3/3
set vlan 104 3/4
set vlan 105 3/5
set vlan 106 3/6
set vlan 107 3/7
set vlan 108 3/8
set vlan 109 3/9
set vlan 110 3/10
set vlan 111 3/11
set vlan 112 3/12
set vlan 113 3/13
set vlan 114 3/14
set vlan 115 3/15
set vlan 116 3/16
set vlan 117 3/17
set vlan 118 3/18
set vlan 119 3/19
set vlan 120 3/20
set vlan 121 3/21
set vlan 122 3/22
set port duplex 3/1-24 full
set multicast router 3/6,3/19-20
set trunk 3/18 off dot1q 1-1005
set trunk 3/19 auto dot1q 1-1005
set trunk 3/22 off dot1q 1-1005
set spantree portfast 3/19 enable
set port channel 3/23-24 mode on
set port channel 3/1-22 mode off
#module 4 : 24-port 100BaseFX MM Ethernet
set vlan 125 4/1
set vlan 126 4/2
set vlan 127 4/3
set vlan 128 4/4
set vlan 129 4/5,4/23-24
set port duplex 4/1-4,4/24 full
set port name 4/24 3640 router subnet
set multicast router 4/2
set trunk 4/1 off dot1q 1-1005
set trunk 4/2 off dot1q 1-1005
set port channel 4/1-5,4/23-24 mode off
#module 5 empty
#module 6 : 48-port 10/100BaseTX Ethernet
set vlan 13 6/25
set vlan 14 6/26
set vlan 15 6/4,6/27
set vlan 16 6/28
set vlan 17 6/29
set vlan 18 6/1-3,6/5-24,6/34,6/39-44,6/46-47
set vlan 19 6/30
set vlan 20 6/31,6/37-38
set vlan 21 6/32
set vlan 22 6/33,6/45
set vlan 25 6/35-36
set port speed 6/3,6/31 10
set port speed 6/1-2,6/7-12,6/16-19,6/25-27,6/29-30,6/33-47 100
set port duplex 6/1-2,6/7-12,6/16,6/18-19,6/29-30,6/33-47 full
set port name 6/3 Vlan 18 Uplink (old)
set port name 6/4 Xerox
set port name 6/11 MS01
set port name 6/19 Web Advisor
set port name 6/21 Library - RS03
set port name 6/25 Vlan 13 Uplink
set port name 6/26 Vlan 14 Uplink
set port name 6/27 Vlan 15 Uplink
set port name 6/28 Vlan 16 Uplink
set port name 6/29 Vlan 17 Uplink
set port name 6/30 Vlan19 Uplink
set port name 6/31 Vlan 20 Uplink
set port name 6/32 Blaster
set port name 6/33 Lion - RS02 (old)
set port name 6/35 Spector Team0 A
set port name 6/36 Spector Team0 B
set port name 6/37 Oracle-1of2
set port name 6/38 Oracle-2of2
set port name 6/39 MS02 OWA
set port name 6/40 MS02 SMTP
set port name 6/41 MS02 Team B1
set port name 6/42 MS01 Team B2
set port name 6/43 MS02 Team A1
set port name 6/44 MS02 Team A2
set port name 6/45 Lion - RS03
set port name 6/47 to internet (PIX)
set multicast router 6/25-28,6/31,6/35-36
set trunk 6/9 off negotiate 1-1005
set spantree portfast 6/9 enable
set port channel 6/9,6/16,6/19-20,6/25-44 mode off
#module 15 : 1-port Multilayer Switch Feature Card
set multicast router 15/1
#module 16 empty
end
Console> (enable)
brocknathan
Level 2
Level 2
I have used Cisco's iptv server along with a 6509. We had over 80 people join a group to watch the super bowl a year ago. There where no problems. Do you have any other routers in your network that have multicast users behind them? Also did you turn CGMP on for both the router and the switch?
Other then our internet router the 6506 is the only router on the network. All network segments collapse back to the 6506.
I didn't see a command to turn on CGMP, for either protion, I think that might be on the Sup II level. I have to work with a Sup IA. If there is a command to enable it on the Sup IA then please share because i didn't see anything to set it. If you think that the problem is that we have a Sup Ia please tell me that too because I would love to know.
Thanks for the post.
aessome
Level 3
Level 3
Hello Matt,
I have also a problem to get my ghost working on the Network. please cann you help me ? how dit you get yours works?
I have this issue
Ghost Server (10.61.10.111) --- vlan 121 (port Gig 5/8)on Cat 6509switch02 --- MSFC ----- vlan 113,114,115--- clients (receivers)
Note that Cat6509 switch 02 and cat 6509 swict 01 are using HSRP and on every etage there are 2 or cat 3548 xl connected to the cat 6509 switches
Thanks for any help
AF
