multiple RR in a cluster!! help
manpan
If there are 2 route reflectors in a cluster,
does they need to be physicaly connected?
Does fully meshed means that they need to be
physically connected?
cetin
no, they don't have to be phy. conn.
Hi.
As you have 2 RR on the same cluster, don't forget to configure the cluster-id on both of them. The cluster clients should connect to all the RRs within the same cluster, in this case they must connect to the 2 RRs.
Hope it helps.
NM
