NAM-2 ver3.1 Daul Capture Facility Data port 1-2
jason.hines
We have a NAM 2 with two data collection ports, 1-2.
Can we capture separate data simultaneously from both ports and display this via the decode.
For example could two people use the NAM at the same time using different data ports without interfering with each others stats.
Could you please tell me how this is achieved, problem being once a person logs in and starts a capture, when a second person logs-in the capture screen appears blanked out and the second persons requirements for the capture can't be configured unless you stop the first persons capture.
From this it appears that two captures from alternate data ports is not possible.
Please advise if there is another method to avoid this problem.
Many Thanks
nikhil_m
You cannot caputre data this way to be displayed
