Need help in migration from Layer2 to layer3
mahmoodmkl
Level 7
Level 7
HI Guys
Need u r help in migration from layer2 switched network to layer3.
here is the setup there are 9 sites connected with a 10gig backbone in a ring.each site has a 6513 but at the data centre site we having two 6513.we are having a combination of voice and data vlans.at present all the sites are connected with layer2 trunks.all the trunks are teminated at the core ie datacentre site.so how should i procedd and what are the advantages of it ie migration.
Mahmood
rais
Level 7
Level 7
For this migration you first need to assign IP addresses to your connections between switches. This could be /30 (or /31, if supported) subnets. You should also consider running some dynamic routing protocol such as OSPF between switches.
Hope this helps.
Thanks for replying.yeh we are planning to run OSPF.as u said that we need to have ip address configured on the swithces so that means that we need to have a MSFC at each site am i right.
Mahmood
Yes, you will need routing capabilities at each site.
Thanks.
