05-14-2004 04:59 AM - edited 03-02-2019 03:42 PM
I've a problem with an dial in on a 3640 with a NM-4B-S/T= and a NM-30DM= .
I can dial in from a PC and it works fine, but when 3 or 4 connections are established sometimes no traffic come back and I've to reconnect and it is then working.
Can someone give me a sample config for it ?
please help
-Carsten
05-14-2004 05:24 AM
Hello Carsten,
can you post your current configuration ? There are numerous bugs related to the NMs - which IOS version are you running ?
GP
05-15-2004 12:32 AM
05-14-2004 08:38 AM
Can you please capture the debugs of a connection that does not pass traffic:
deb isdn q931/ deb modem / deb modem csm / deb ppp nego.
1) Do all the dial up connections stop passing traffic or just the latest connection?
2)After the call is connected: sh ip route
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080093c6e.shtml
Thanks, Mak.
05-16-2004 11:17 AM
Do all the calls stop passing IP traffic when the problem occurs? If not, see if you encounter the problem only if you connect to a certain digital modem.
Does it help if you enable "ip cef"?
~Zulfi
