Net flow Configuration
Iliriana
When you configure netflow monitor and you dont configure following commands on the interface,
For example :
vlan configuration 666 ip flow monitor netflow-Monitor input
 will netflow work ?
balaji.bandi
it will not collect any flows, if the interface not configured.
BB
Thank you for your response
cmarva
Level 4
Level 4
no. As per the docs on FNF, you need to define a record, an exporter, and a montior. Once all those are in place it will work.
chris
