Netscape client on Unix - doesn't work
pvignaud
I'm running the netscape client (4.76 + JRE 1.3.1) on the same platform than CW2000 LMS 2.1 (solaris 2.8)
The left frame at the logging page isn't working, I don't receive the login and password box.
At the message box at the end of the browser window, I receive the following message "com.cisco.nm.cmf.desktop.csNavigator class com/cisco/nm/cmf/desktop/csNavigator got a security violation : method verification error.
Any ideas ???
Patrick Vignaud.
rmushtaq
Level 8
Level 8
Does this happen only on this UNIX client or with other WIndows clients with IE as well?. Does clearing the browser and plug-in cache on this client make any difference?
I've cleared the browser and even restart the browser (deleting the .java and .netscape directory inside the home user). It doesn't change.
For the browser, if I use a PC with IE it works. But don't tell me that's a browser specific problem. I've the recommended version of the browser and Java.
Thanks.
Patrick.
