Network module compatibility for 3700 series routers
NB243_243
Is the NM-4E module compatible with the 3725 router?
Thanks in advance
NB243
It appears NM-4E isn't compatible with 3700 series routers.
Here's a couple of links that may help you choose the supported modules.
http://www.cisco.com/en/US/products/hw/routers/ps282/products_relevant_interfaces_and_modules.html
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b89.html
HTH,
Sundar
