NEW TO CISCO SWITCHES - PLEASE HELP
rania20052006
DEAR ALL,
I AM STILL NEW TO THE CISCO SWITCHS, AND WHILE I WAS WORKING I FOUND SOMETHING FOR CISCO SWITCH WHICH I AM WORKING ON IT .
I AM HAVEING CISCO SWITCH 2950 SERIES AND I AM USING THE CONSOL TO CONNECT TO IT .
NOW, MY MANGER ASKED ME TO PROVIDE TELNET CONNECTION TO THE SWITCH WITH PASSWORD.
I DID IT AND ITS WORKING.
HE IS ASKING ME FOR SOMETHING ELSE, HE WANTS TO CRATE USER NAME & PASSWORD FOR EACH USER ON THE CISCO SWITCH WHICH WE HAVE & EVERY ONE WHEN HE IS TELNET TO THE SWITCH HE SHOULD PUT HIS USER NAME & PASWWORD & THEN CONNECT.
MY QUESTION IS, HOW CAN I MAKE THIS TO WORK WITHOUT USING ( CISCO SECURE TACKS ) , IS IT POSSIBLE.
IF SO, CAN ANY ONE HELP ME TO DO THAT .,
7 Replies 7
you can use local authentication on the switch. Let's say you want user Ahmed with password ramadan to connect to the switch, you would define a local username and password pair on the switch:
Switch#conf t
Switch(config)#username Ahmed password 0 ramadan
Then, under th terminal lines, you would configure 'login local':
Switch#conf t
Switch(config)#line vty 0 4
Switch(config-line)#login local
Now every time somebody telnets into the switch, that person has to enter a valid username and password, which has to be configured on the switch locally as described above...
Does that make sense ?
GP
Hi;
First thanks for your reply .
Happy Ramadan for you .
Regarding that, if i have say 5 users & all of them will connect to the switch by tellnet, so the steps which i have to follow is :-
1- create Password for each telnet line.
2- Create user name & Password for each user.
but why i have to make the login local as you mention in that step:-
Switch#conf t
As-Salaam Alaikom,
exactly, you need to create a username & password for each user. The 'login local' tells the line to check the local database for authentication, that is, to check the username and passwords you have previously configured...
Does that make sense ? Let me know if you need more help.
GP
Thanks for your reply.
Actually , i do understand what do you mean by that.
but, can i know what is the different between the using user name & Password locally & using the cisco scure tacks .
can you also write the command which i need to write it on the switch to do that .
Thanks for your help.
for TACACS+ authentication on the VTY lines, configure the following on your switch:
aaa group server tacacs+ tacgrp server x.x.x.x
aaa authentication login default local
aaa authentication login login-auth-list group tacgrp local line
aaa authorization exec login-auth-list group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
line vty 0 4
access-class 11 in
login authentication login-auth-list
Is that what you are asking ?
GP
pankajs
you can use username password command in global configuration mode. Then mention login local in vty line mode.
hacabrera001
Yes, It is totally possible...
Instead of using a TACACS+ (or RADIUS) Server to authenticate the users you can just use the local database to do it....
The only problem is that you need to create all the usernames and passwords on the local database.
If that is OK with you, you can just use the following commands:
username USER password PASS
aaa new-model
On the first line you setup a username (USER) and password (PASS) for each user you have. NOTE: Be very careful so you dont get locked out of your switch. First of all, Create a username and password for the administrator (you), then you can create all the rest of the users.
On the Second line you tell the Switch/Router that it will take from now on a new database instance. (In this case it is gonna be a local database).
On the third line you tell the Switch/Router that it will authenticate every login attempt with the local database of users (the one that you just created).
How many users are going to be loging on to the Switch??? If you have so many I'm pretty sure that your best option is TACACS+ or RADIUS (NOTE: It can be an OpenSource TACACS+ or RADIUS Server, It doesnt have to be a Cisco Secure ACS Server), but, if you have less than 20 users I guess that the local database its going to be enough.
If you need any other information please do not hesitate in contact me.
See Ya!!!
