Nexus 9000 temperature Minor alarm
joseluis68
hello,
I have a Cisco Nexus 9000
sh environment temperature
Temperature:
Module Sensor MajorThresh MinorThres CurTemp Status
                        (Celsius)       (Celsius)    (Celsius)
1 FRONT          70                 42             43            MinorAlarm
1 BACK            80                 70             42            Ok
1 CPU              90                 80             58            Ok
1 Homewood   110               90             56            Ok
Temperature in Front ranges between 41 and 43.
How can I change MinorThres (to 44)?
Hi @joseluis68
Creating a Supplemental Policy for the Temperature Threshold Event
This example shows how to create a supplemental policy using the event temperature command:
[no] event temperature [mod module-number] [sensor sensor-number] threshold {major | minor | any}
In addition to the default policy, this example shows how to execute the policy myappletname and action 1 if the temperature crosses the minor threshold on sensor 3 of module 2:
switch# configure terminal
switch(config)# event manager applet myappletname
switch(config-applet)# event temperature module 2 sensor 3 threshold minor
switch(config-applet)# action 1 cli “show environ temperature”
switch(config-applet)# end
this is the official page
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide/sm_eem_events_and_examples.html
remember to rate this answer as help
Hi @joseluis68
thanks for assistance provided @Javier Acuña
Thanks for the help.
@joseluis68 estamos para servir.
Saludos cordiales.
