02-03-2005 08:15 AM - edited 03-02-2019 09:27 PM
HI,
We have a new 2610XM router, in which we inserted a NM 4 A/S card which was working in other 2610 router.
Upon booting the new 2610XM router with this card, its giving the following error.
%PA-3-NOTSUPPORTED (x1): PA in slot 1 is not supported on this chassis
02-03-2005 08:22 AM
What version of IOS do you have running on the new router. You should at least have
12.1(14), 12.2(8)T1, 12.2(11)T, 12.2(11)YT, 12.2(12), 12.2(15)ZJ, 12.3(1), 12.3(2)T
Hope this helps
02-03-2005 08:54 AM
The router is running IOS Version 12.3(10)
02-03-2005 08:24 AM
This module should be supported on almost every version of Cisco IOS starting with 11.3T. Dont know if this is a chassis problem. Try adding another network module on the XM router (if you have one) and see if that is detected.
