Normal and Extended Burst values for rate-limit command
kkalaycioglu
Level 4
Level 4
What is the guideline for determining the normal and extended burst values used in rate-limit commands? Some documents say that
normal burst value = (bps/8)*1.5
exd.burst value =2 * normal burst value
For example supposing that I'm trying to limit rate of the traffic incoming on an ethernet interface to 512Kbps, what values should I use?
Regards.
gmarogi
Level 5
Level 5
This is the formula that Cisco recommends. For 512 Kbps, you would have to use the command ' rate-limit input 512000 96000 192000 conform-action transmit exceed-action drop' . For more details see http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/qos_c/qcprt4/qcdpolsh.htm#xtocid215905
