Novell connectivity problem in Catalyst 2950 Switch
ahsin.inayat
We have purchased new 2950 switches but we are unable to connect the pcs with novell netware v3.12 server. we are using 3com's ISA network adapter in server and 3com's 3c905b network adapter in workstations. What should i do to solve this problem
glen.grant
Did you turn on portfast for all your client pc"s ? It's possible that your clients are timing out before spanning tree puts the port into forwarding state . For each port use the "spantree portfast" command .
