ospf routing path
bmehdi
Hi ,
we have three router connected to each other via frame-relay.My router is connected to the other two via frame-relay.problem is all the routes my router learns (of both router ) is from serial 1/0.1.
int serial1/0.1 point-to-point
ip address 10.1.1.253 255.255.255.252
ip address 10.1.1.249 255.255.255.252
ospf configuration is
router ospf 10
network 10.2.1.1 0.0.0.255 area 20(my router network)
network 10.1.1.240 0.0.0.15 area 0
show ip ospf neighbor identifies both the neighboirs in full state.
Any suggestions
16 Replies 16
My router info.
sh ip ospf database
h ip ospf database
OSPF Router with ID (10.23.1.1) (Process ID 20)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
10.21.1.1 10.21.1.1 128 0x8000060D 0x5D51 4
10.22.1.1 10.22.1.1 127 0x80000734 0xF9CD 4
10.23.1.1 10.23.1.1 158 0x8000011F 0xCC0D 4
Summary Net Link States (Area 0)
10.22.0.0 10.22.1.1 636 0x80002DA1 0x5D38
10.21.1.0 10.21.1.1 159 0x8000009C 0xCFF4
10.21.2.0 10.21.1.1 159 0x8000061A 0xA36B
10.23.1.0 10.23.1.1 1346 0x80000101 0xEF6D
10.23.2.0 10.23.1.1 1346 0x80000101 0xD05A
Summary ASB Link States (Area 0)
10.21.11.1 10.21.1.1 175 0x8000061A 0x6A3C
Router Link States (Area 20)
10.23.1.1 10.23.1.1 190 0x80000C1F 0x4F8E 18
10.23.11.1 10.23.11.1 336 0x8000583F 0x38A3 5
Summary Net Link States (Area 20)
10.22.0.0 10.23.1.1 1441 0x80000002 0xE916
10.22.254.244 10.23.1.1 1345 0x80000003 0x45C9
10.22.254.248 10.23.1.1 1841 0x80000001 0x6C7F
10.22.254.252 10.23.1.1 1345 0x80000003 0x774F
10.21.1.0 10.23.1.1 161 0x80000001 0x14C8
sh ip ospf border-routers
ospf process 20 internal routing table
codes:i-Intra-area route , I- Inter-area route
i 10.22.1.1.[48] via 10.1.254.254 serial 2/0.1 ,ABR,Area 0 ,spf 30
i 10.21.1.1 [112] via 10.1.254.254 serial 2/0.1 ,ABR,Area 0 ,spf 34
I 10.21.11.1 [162] via 10.1.254.254 ,ASBR,Area 0,spf 30
As you can see the two ABR's that im connected to are advertised by only serial2/0.1 while the 10.21.1.1 is attached to serial 1/0.1
Please send the exact commands that Russell requested, as repeated below. sh ip ospf database shows a summarised form whereas the commands below give more details, including metrics,
show ip ospf data router 10.21.1.1
show ip ospf data router 10.22.1.1
show ip ospf data router 10.23.1.1
Ian
