PC connecting to 7940 phone connecting to 3560
thomuff
Level 3
Level 3
How would you configure mac-address sticky on the port for the voice vlan and access vlan to limit to 1 mac address per vlan? Also, is there gotchas running dot1x on the port?
Basically we want to connect Pc to 7940 to Catalyst 3560, when one or the other is replaced, it will err-disable the port.
tekha
Level 3
Level 3
My guess is that it would be something like this:
interface FastEthernet0/20
description CP7912 0012.7f9b.83ca Phone
switchport access vlan 100
switchport mode access
switchport voice vlan 97
switchport port-security maximum 1 vlan access
switchport port-security maximum 1 vlan voice
switchport port-security mac-address sticky
Afterwards the switch added this to the running config:
switchport port-security mac-address sticky 0012.7f9b.83ca vlan voice
I would imagine it would do the same for the access vlan, but I don't have a PC on the back of the phone, so I don't really know.
See if it works, and please let me know.
OK, it doesn't work.
I've to make the config look like this insteed:
switchport port-security maximum 3
switchport port-security maximum 2 vlan access
switchport port-security violation restrict
switchport port-security mac-address sticky 0050.dad9.ff0a
The last three lines are made automatically and if the CP7940 works like my CP7912, then for some reason, the phones MAC address appears in both access and voice vlan. Sounds like a bug, but it works with "max 3" and "max 2 vlan access".
I choose "violation restrict", insteed of "violation shutdown", because if a user was to change the PC with another PC, the port in the switch would allso turn off access to the phone.
thank you
