11-04-2002 02:09 AM - edited 03-02-2019 02:36 AM
What is the equivalent IOS switch command for the Catalyst 6509 CAT OS <set port security> command.
on other IOS switches like the 3550 series there is a command - switchport port-security. i need to know the command on CAT6509
Solved! Go to Solution.
11-04-2002 09:37 AM
Release 12.1(13)E and later releases support the port security feature.
eg.
Router(config-if)# switchport mode access
Router(config-if)# switchport port-security
Router(config-if)# switchport port-security maximum 1
Router(config-if)# switchport port-security mac-address xxxx.xxxx.xxxx
Router(config-if)# switchport port-security violation shutdown
Hope it helps.
Steve
11-04-2002 09:37 AM
eg.
Hope it helps.
Steve
