Possible issues with Unicast reverse path forwarding in multihomed network
r.cheung
Are there any issues with enabling unicast reverse path forwarding on a partially meshed network? If there are 3 sites, (A, B, C) connected like a triangle, would there be issues with enabling it on site A, if it only connects to Site B to reach Site C when the circuit between A and C goes down? Routing is performed by EIGRP. That way, there really wouldn't be any asymmetric routing.
csthomas
Does "A" have full routes? If you're trying to use RPF for security, having a default route pretty much destroys it.
zaziz
InternetA---A-----B----C-----Internet-C
link between A and C is down.
where is RPF enabled. link between
1)A to B
2) B to A
3)B to C
4)C to B
For Internet Traffic it really depends where is the traffic entering your network and where it will exit.
for Internal traffic RPF should work fine in such scenario
