Power Consumption for IE4000 switches
Stuart Read
Beginner
Beginner
Our project has an application that sees the IE4000 switch mounted inside an IP55 vented (not actively cooled) cabinet with the accompanying 170 W PSU. The switch is 48V DC fed, and is used to power remote IP telephony, WLAN and IP CCTV, with 8-ports of PoE+ potentially required. Our calculations are:
IE4000 Power Consumption             Worst Case 42 Watts
Power Supply efficiency                  Worst Case 90% for maximum PSU size of 280 Watts is 28 Watts heat dissipation.
PoE                                                    Worst Case 2% or PoE power 30 Watts x 8 = 4.8 watts
Thus the total heat dissipation for a BoP with a PSU and supplying 8 PoE+ devices is  42+28+4.8 = 74.8
Thus the BTU at 3.41 BTU/hr per Watt = 255 BTU/hr and if the PSU is not inside the cabinet then it is 159.6 BTU/hr
Is this assumption correct? Our client has a requirement that we can provide an accurate response that clarifies how much heat dissipation is generated/occuring at the switch, when the devices it is remotely powering are drawing full power i.e 8 POE+ ports (8 x 30) + 42 watts for the IE4000 = 280 watts.
Any help would be gratefully received.
Many thanks,
Stuart Read
drtorr
Beginner
Beginner
I have the same question but can't get a hold of anyone at Cisco.
Recognize Your Peers
