Problem configuring Link Fragmentation & Interleaving
n.oneill
I have configured QoS on my ADSL router but the LFI doesn't appear to work. When I do a "show ppp multilink" it says there are no active bundles.
Relevant config as follows:
ip cef
class-map match-all cs
match access-group 120
policy-map qos
class cs
priority 128
class class-default
fair-queue
interface Virtual-Template1
mtu 1458
no ip address
ppp multilink
ppp multilink fragment-delay 10
ppp multilink interleave
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/16 ilmi
bundle-enable
dsl operating-mode itu-dmt
interface ATM0.38 point-to-point
mtu 1458
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer1
description "BT Openworld"
mtu 1458
bandwidth 512
ip address negotiated
ip access-group 111 in
no ip redirects
no ip proxy-arp
ip nat outside
ip inspect INBOUND in
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer-group 1
service-policy output qos
no cdp enable
ppp authentication chap callin
ppp chap hostname ************
ppp chap password 7 ***********
ppp multilink
access-list 120 permit udp any host 195.20.108.10 eq 27050
Any packets matching access-list 120 are dropped unless I remove the ppp multilink statements
Any ideas?
deilert
Level 6
Level 6
On what interface are you trying to apply this on ? the AYM PVC or the dialer or both ?
As per the following article:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1834/products_feature_guide09186a00800804c1.html
WHich is apply it to the dialer and map the dialer to the physical interface.
