Problem to be solved
suresharja
Hi All,
Two locations connected by two links(one is leased line the other is VPN-MPLS) and using 3745 routers both sides.I learnt that Fast switching is enabled BYDEFAULT. If that is the case , I see some packets via leased line and some via VPN(Using Extended ping).I want to disable per packet load balancing and enable per session load balancing. How can I do that???
Thanks In Advance...
suresh arja
15 Replies 15
From which interface is traffic entering the router from? Can you do a show cef also, where input_interface is the interface from where the origin client resides.
All counters show 0 packets in the output you sent. Can you initiate a continuous ping to the 10.133.x.x destination and then get the output and post it here. There is nothing out that seems wrong with cef here, at least not anything that jumps out at the moment.
