Problem to remove route.
Ramirov
Hi , I have a problem with a 3750 (C3750E-UNIVERSALK9-M), Version 12.2(58)SE2) I cant remove a route
xxxxxxx(config)#no ip route 10.24.0.0 255.248.0.0 10.59.2.17 name xxxxxxx track 54
%No matching route to delete
I tried remove the track without success , and tried created a new track with a new route but when I try remove the original route , the new route with the new track is removed.
some idea???
Thanks.
Hello Mikael , it didn't works , We reloaded the device and then remove the route correctly.
Regards.
mlund
Level 7
Level 7
Try with "show run | inc ip route" and then copy the route as it is shown.
/Mikael
Regards.
