Problem with ANIServer process in LMS 3.2
j-fragoso
When I click in topology services the next message appears (View attachment)
What is the problem?
Best regards
Ganesh Hariharan
As per the error it says it is unable to find the hostname of the server through which it is connecting,can you check the hostname is added in DNS and you are aslo reachable to server via hostname.
Ganesh.H
