problem with callback on Router 3725 (digital modems )
pavlosd
Level 2
Level 2
Hello Guys,
I was following the example under http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094338.shtml in order to setup a callback server. Unfortunately it does not work...
Attached is the conf and debug files...
Can anybody help?
Version
IOS (tm) 3700 Software (C3725-IK9S-M), Version 12.3(6), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 11-Feb-04 15:42 by kellythw
Image text-base: 0x60008AF4, data-base: 0x61DC8000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
Medousa uptime is 1 hour, 55 minutes
System returned to ROM by reload at 17:34:58 EEST Wed Jun 16 2004
System restarted at 17:36:29 EEST Wed Jun 16 2004
System image file is "flash:c3725-ik9s-mz.123-6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 3725 (R7000) processor (revision 0.1) with 120832K/10240K bytes of memory.
Processor board ID JMX0817L3R1
R7000 CPU at 240MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
MICA-6DM Firmware: CP ver 2940 - 7/24/2002, SP ver 2940 - 7/24/2002.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
8 ISDN Basic Rate interface(s)
12 terminal line(s)
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of non-volatile configuration memory.
125184K bytes of ATA System CompactFlash (Read/Write)
Slot 2:MICA-6DM Firmware, Source - IOS
CP ver 2940 - 7/24/2002, CheckSum BB345F13.
MICA 0: HW Version 1.0, Serial Number 31892928.
MICA 1: HW Version 1.1, Serial Number 31891928.
MICA 2: Not Installed.
MICA 3: Not Installed.
MICA 4: Not Installed.
Here is what I see different between these 2 calls (router initiated callback & reverse telnet ATDT call)
1. The numbers that are dialed are different, 22111122 with reverse telnet & 22112211 as per configuration for callback. Will be interesting to see when you dial the 22112211 with reverse telnet session (maybe it will not make a difference but since we were getting unallocated/ unassigned number from the switch when dialing 22112211..1st set of debugs)
2. The reverse telnet logs below for atdt22111122 show that we have past the first switch (closest to the calling side) but we never reach CONNECT state on the ISDN layer so the modem handshake will not be able to ride over the ISDN connectivity (should receive a RX <- CONNECT ) & see modem waiting for ISDN connectivity (CSM_PROC_OC_ISDN_CONNECT_PENDING)
Jun 17 13:17:04: ISDN BR1/7 Q931: RX <- ALERTING pd = 8 callref = 0x95
Progress Ind i = 0x8288 - In-band info or appropriate now available
Jun 17 13:17:04: CSM: MODEM_REPORT from 1/7:0, call_id=0x8024, event=0x5, cause=0x0, dchan_idb=0x6389C290
Jun 17 13:17:04: Modem 2/0 CSM: MODEM_REPORT rcvd DEV_CALL_PROGRESSING for call_id 0x8024
Jun 17 13:17:04: Modem 2/0 CSM: (CSM_PROC_OC_ISDN_CONNECT_PENDING)<--ISDN_CALL_PROGRESSING
Jun 17 13:17:05: Modem 2/0 CSM: (CSM_PROC_OC_ISDN_CONNECT_PENDING)<--MODEM_TONE_DETECTED
Jun 17 13:17:05: Modem 2/0 Mica: Detected Dial tone
Jun 17 13:17:10: ISDN BR1/7 Q931: RX <- DISCONNECT pd = 8 callref = 0x95
Thanks, Mak
8 Replies 8
makchitale
Level 6
Level 6
The callback process looks good till timestamp 19:12:38, after the BRI attempts to callback we receive a disconnect from the telco switch:
Jun 16 19:12:38: ISDN BR1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x8C
Cause i = 0x8281 - Unallocated/unassigned number
82 - From the public network near the local user (local telco switch).
81-The ISDN number is sent to the switch in the correct format. However, the number is not assigned to destination equipment.
As a quick test, can you reverse telnet into a modem & try calling the same number “ATDT22112211” & see if the call goes through .
Thanks, Mak
Hello Mak, Reverse telneting and call from a digital modem seems to work fine as well. Find attached the reverse telnet debug traces.....
Thanks, Mak
Ok, here is a trace with calling itself(22112211).
Can you suggest anything?
Do not see the "deb isdn q931" output in these logs.
Another way to test is reverse telnet, then ATDTxxx & we should see the RI (ring indicator) flashing on modem.
Thanks, Mak
Hi Mak,
The following rather strange problem occurs, sometimes the call succeeds and sometimes it fails. As you said, it has to do with the CONNECT state from ISDN q931. I am using isdn switch-type basic-net3 so I do not configure any values from my site the ISDN site (i.e. spid). Any ideas why it may sometime succeed and others fail? The same senario occurs with callback. If I keep trying it will eventually succeed.
Thanks.
Is this in a lab environment? Do we have an ISDN simulator? If yes, there is some inconsistent behaviour in the simulator.
If no, then we need to get the ISDN provider involved. The Access server seems to be negotiating & initiating the callback.
Thanks, Mak
Hi Mak,
it's a live environment. Ok I will see what I can do. Thanks for all your time and help.
