Problem with cisco 1841
ystem Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x202b7f8
after 10-15 seconds, IOS start with decompresing, but I don't know what is problem with this line form top, first I remove flash from my first 1841(he don'e any error but when i back CF, error start ), and put in second router 1841, and he have the problem
What I can to do, to fix problem, I have 128MB SDRAM, 64MB CF
CCNA R&S, CCNA Security
8 Replies 8
paolo bevilacqua
It is impossible to understand you, try again.
I have 2 routers, one is my, second is from my friend, my is 100% fully operational, friend sad for his router, router do not have CF and SDRAM memory but is fully operational, in that router I put my SDRAM and CF (from my router) and turn on, and I get bottom message, after 10 - 15 seconds, IOS start to uncompress, and everything is OK, I don't know what is problem, I put back my CF and SDRAM, and my router get the same problem, the same message in terminal,
I do not know what is  created this problem, maybe it is and maybe it is not, I wonder why now I get that message
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
PLD version 0x10
Main memory is configured to 64 bit mode with parity disabled     -  WHAT IS THIS, WHAT IS MEAN ?
These are normal messages about router hardware and do not indicate any problem.
In generaly I am confuse with message Main memory is configured to 64 bit mode with parity disabled, this message is OK????, but why is not received before, the first time when I received message is when I back CF and SDRAM memory in my router
Not all systems print the same messages. Or maybe you do not remember exacly what it was printing before.
As indicated above, all is normal and you do not have to worry.
Txn on replay ))))
Have a nice day
What SDRAM memory I can buy for my cisco 1841, any laptop SDRAM memory ? any brand ?
You can search sellers online on the popular auction website, any reputable vendor is ok.
Thank you for the nice rating and good luck!
