Problem with HSRP in IPSec
fawad.alam
I am using HSRP as part of High Availability IPSec to ensure head-end IPSec peer address is always available.
I am applying CRYPTO MAP command on interface with REDUNDANCY keyword to achieve the deisred result.
It is working for me as I see the IPsec peers get established using HSRP virtual IP address on Site A & B.
The problem : I was dropping packets frequesntly. When I looked at the HSRP active standby status on the two routers at site A for the interface configured with REDUNDANCY keyword, both routers are showing active for the standby group and remote router is shown as unknown. I see same problem at Site B.
What is required under the HSRP configuration along with REDUNDANCY Keyword. I can not ping the interface of the HSRP group peer as well on both sites.
Any help would be highly appreciated.
Thanks..Alam
sstudsdahl
Level 4
Level 4
Alam,
The interfaces that you have setup for HSRP need to be able to communicate with each other via layer 2 so that hello packets can be exchanged. If the two routers can't talk to each other via the HSRP enabled interfaces, both side will show active and the remote router as unknown.
Here is a link that describes how HSRP works and gives some example network topolgies with configurations.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/cs009.htm
Steve
