03-16-2004 01:17 PM - edited 03-02-2019 02:19 PM
I have a cisco 3745 with a t1 controller module connecting via a full t1 ppp link to an ibm 2210 router. We cannot get the interface on the cisco router to come up and establish communications. We are not using an external csu/dsu.
Any help?
03-22-2004 11:56 AM
Can you use a cisco 3745 on both sides to rule out whether the problem is with hardware or the link, try swapping the cards and the line .
03-22-2004 01:08 PM
The link in question is actually up and running currently between two 2210s. It's not a new ppp link. It's only when we move it to the 3745 on the one side that it doesn't come up.
03-22-2004 02:36 PM
Do you have a link light on the t1 module?
03-22-2004 03:19 PM
Yes we do. No Alarms at all but when you look at the interface it shows as "up" down" it never gets to "up" "up".
03-22-2004 03:30 PM
make sure your encapsulation and time slot settings match on both sides.
03-22-2004 03:47 PM
Here is a link to a flow chart I use for troubleshooting t1 issues.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a5f40.shtml
BT
