Problem with software management in RME 3.1
jeff.yau
I am using cw2k (NT) version with RME 3.1 bundled.
When I used software management to add or distribute IOS image of routers and swithces, the following error message showed:
Uploading image bootflash:c4500-boot-mz.113-8 from 10.10.10.1
Start time: 10 Apr 2002 16:00:08 CCT
Error Info Code: 4167.
Device Error: The copy to/from operation failed.
Probable Cause: Cannot set SNMP variable for flash copy
operation. Recommended Action: Verify connectivity to the
device using ping. Verify the name resolution for the device
on the Resource Manager Essentials server. Verify that
read-write community strings match in the device and in the
Resource Manager Essentials database, then retry the
operation. If the problem persists, contact your technical
support representative for assistance.
I have checked the snmp community strings and they are correctly set.
So Could anyone tell me what I can do.
12 Replies 12
rmushtaq
Level 8
Level 8
You can consider upgrading to RME 3.3
How can I get the upgrading information?
Is it free or not?
Mushtaq, I don't get it this. Do you mean that RME 3.1 does not work at all for Software Manager (upload/download IOS)? If you mean upgrade to RME 3.3, are you saying Cisco is admitting there's a bug for this - and giving a free RME 3.3 to all current users of RME3.1?
Jeff, what I could suggest here is probably double confirm whether you have the correct community read/write strings for the device? Is there any firewall rules or access-list blocking for SNMP from you to the device? Are your RME3.1 having the device as you managed devices?
Kevin
I used the word 'consider' for the upgrade, not that it's a must :-). You can do a CCO Bug Toolkit search to see if this is a known issue or else. If everything else is good like, strings, passwords etc, get a sniffer trace to see where exactly RME is failing. You can then open a case with TAC for further assistance as well.
Hi Mushtaq,
Thanks very much on this! I've current users using RME3.1, but they don't have any problems on this, so initially I thought it's a bug & will get free copies of RME3.3... :-)
You are right to go for trace up to RME to see if there's any problem with that. Good luck, Jeff...
Best Regards,
Kevin
rmushtaq
Level 8
Level 8
What type of device is this?. Specific Model and current IOS running on it?
Actually there are several devices with different IOS versions that are running in my company.
I am quite sure there are no problems for the community strings. Other snmp related applications such as cisco view are normally run.
That's why I feel so confusing.
And my company is using CW2K on NT4sp6. No patch was installed.
Is there any patch for the CW2K?
There was a patch released on CCO for Java related issues with CW2K but that was for RME 3.3 and not for RME 3.1 which you're using. Getting a sniffer trace might be a good idea at this time to exactly see what's going on here.
Hi rmushtaq,
Thank you for your suggestion.
I want to know where I can get the sniffer trace? Is it free downloaded?
You can use Ethereal which is a free ware software just like Sniffer Pro. You can download it from http://www.ethereal.com
Thank you for your kindly help.
