Problem with the WAN link...PLease Help
I have the following problem with this interface. The link keeps good for few minutes an another time I lost the conection.Sometimes it goes up sometimes it goes down. This interface is conected to a Promina wich is conected via RF.
Do you have any idea of what can I do to fix this problem?
Thanks a lot for your help
Serial1 is up, line protocol is up
Hardware is HD64570
Description: Enlace Wan er-guamach1 - er-plcgua1
Internet address is 167.175.48.10/30
MTU 1500 bytes, BW 1024 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 16:16:33
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 30000 bits/sec, 10 packets/sec
5 minute output rate 6000 bits/sec, 10 packets/sec
344583 packets input, 312103564 bytes, 0 no buffer
Received 7250 broadcasts, 0 runts, 0 giants, 0 throttles
3111 input errors, 231 CRC, 0 frame, 0 overrun, 180 ignored, 72 abort
257778 packets output, 25596295 bytes, 0 underruns
0 output errors, 0 collisions, 1430 interface resets
20 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
smif101
Level 4
Level 4
I would suggest that you start doing loops in the promina network to see where the problem is starting at. Start with a local loop in house and keep going until you are at the patch panel for the remote router.
Jason Smith
www.smif101.com
