Problems to comunicate Cisco 3750 with 2960
Junior27
We have a Cisco 3750 with 12 Fiber Ports. Went this switch was connected to old 2950 works fine but know I am changing to 2960 switches and dont communicate between them. In the Cisco 3750 the trunk port are setup with;
switchport mode trunk
In the 2960 with
because the 2960 dont have the option of the encapsulation dot1q
And I cant ping from the 3750 to the 2960 and vise-versa
Any recomendation or additional instruction that I need to add to the 2960 switches?
Please let me know.
As per your config my understanding
3750 (port  Gig 3/0/1 ) ---Connected --- (Port  Gig 1/0/49) ---2960
Is this correct  ?
If So on your 3750 all the ports are in Trunk Mode.
Form testing  on 3750 do following steps : ( No changes required on 2960X side for now).
config t
Default interface GigabitEthernet3/0/2
Default interface GigabitEthernet3/0/3
switchport mode access
switchport access vlan 10
interface Vlan1
no shutdown
interface Vlan10
no shutdown
Try ping locally
Switch#ping 172.10.5.11
remote  ping
Switch#ping 172.10.5.15
Switch#ping 192.168.120.11
remote  ping
Switch#ping 192.168.120.15
Post the results.
BB
9 Replies 9
Leo Laohoo
Post the complete output to the command "sh interface trunk".
balaji.bandi
adding to other post can you also post
show vlan
show run interface XX (part of trunk)
BB
Switch#sh run interface vlan 10
Building configuration...
Current configuration : 111 bytes
interface Vlan10
ip address 172.10.5.11 255.255.248.0
no ip route-cache
no ip mroute-cache
shutdown
end
Sending 5, 100-byte ICMP Echos to 172.10.5.11, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Switch#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi3/0/1 on 802.1q trunking 1
Gi3/0/12 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi3/0/1 1-4094
Gi3/0/12 1-4094
Port Vlans allowed and active in management domain
Gi3/0/1 1
Gi3/0/12 1
Port Vlans in spanning tree forwarding state and not pruned
Gi3/0/1 1
Gi3/0/12 1
Switch#
High level
interface Vlan10
no ip route-cache
no ip mroute-cache
shutdown   <--- no shut
end
test and advise.
BB
I already made the no shut went I saw that is shutdown
but continue with the same problem that no traffic between the 3750 and the 2 2960.
In the 2960 I can ping the vlan 10 with any problem but in the 3750 I cant ping it
Can you post both the device full configuration.
show run from both the devices.
BB
Switch 3750
sh conf
Using 2194 out of 524288 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 5 $1$uz8x$CZaA7NOpnMspdsWNVWZbA/
enable password Cisco
no aaa new-model
switch 3 provision ws-c3750g-12s
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet3/0/1
description trunk port
interface GigabitEthernet3/0/4
interface GigabitEthernet3/0/5
interface GigabitEthernet3/0/6
interface GigabitEthernet3/0/7
interface GigabitEthernet3/0/8
interface GigabitEthernet3/0/9
interface GigabitEthernet3/0/10
interface GigabitEthernet3/0/11
interface GigabitEthernet3/0/12
interface Vlan1
ip address 192.168.120.11 255.255.248.0
shutdown
interface Vlan10
no ip route-cache
no ip mroute-cache
ip classless
ip http server
ip http secure-server
line con 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
Sending 5, 100-byte ICMP Echos to 172.10.5.15, timeout is 2 seconds:
Switch 2960
Using 6320 out of 524288 bytes
! Last configuration change at 06:25:15 UTC Wed Mar 30 2011
! NVRAM config last updated at 06:26:09 UTC Wed Mar 30 2011
version 15.0
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 5 $1$GbJ3$njIVFNjewYlaEkk4G4KUU1
no aaa new-model
switch 1 provision ws-c2960s-48fpd-l
crypto pki trustpoint TP-self-signed-3269795968
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3269795968
revocation-check none
rsakeypair TP-self-signed-3269795968
crypto pki certificate chain TP-self-signed-3269795968
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
description vlan 1
spanning-tree portfast
interface GigabitEthernet1/0/2
description vlan 1
interface GigabitEthernet1/0/3
description vlan 1
interface GigabitEthernet1/0/4
description vlan 1
interface GigabitEthernet1/0/5
description vlan 1
interface GigabitEthernet1/0/6
description vlan 1
interface GigabitEthernet1/0/7
description vlan 1
interface GigabitEthernet1/0/8
description vlan 1
interface GigabitEthernet1/0/9
description vlan 1
interface GigabitEthernet1/0/10
description vlan 1
interface GigabitEthernet1/0/11
description vlan 1
interface GigabitEthernet1/0/12
description vlan 1
interface GigabitEthernet1/0/13
description vlan 1
interface GigabitEthernet1/0/14
description vlan 1
interface GigabitEthernet1/0/15
description vlan 1
interface GigabitEthernet1/0/16
description vlan 1
interface GigabitEthernet1/0/17
description vlan 1
interface GigabitEthernet1/0/18
description vlan 1
interface GigabitEthernet1/0/19
description vlan 1
interface GigabitEthernet1/0/20
description vlan 1
interface GigabitEthernet1/0/21
description vlan 1
interface GigabitEthernet1/0/22
description vlan 1
interface GigabitEthernet1/0/23
description vlan 1
interface GigabitEthernet1/0/24
description vlan 1
interface GigabitEthernet1/0/25
description vlan 1
interface GigabitEthernet1/0/26
description vlan 1
interface GigabitEthernet1/0/27
description vlan 1
interface GigabitEthernet1/0/28
description vlan 1
interface GigabitEthernet1/0/29
description vlan 1
interface GigabitEthernet1/0/30
description vlan 1
interface GigabitEthernet1/0/31
description vlan 1
interface GigabitEthernet1/0/32
description vlan 1
interface GigabitEthernet1/0/33
description vlan 1
interface GigabitEthernet1/0/34
description vlan 1
interface GigabitEthernet1/0/35
description vlan 1
interface GigabitEthernet1/0/36
description vlan 1
interface GigabitEthernet1/0/37
description vlan 1
interface GigabitEthernet1/0/38
description vlan 1
interface GigabitEthernet1/0/39
description vlan 1
interface GigabitEthernet1/0/40
description vlan 1
interface GigabitEthernet1/0/41
description vlan 1
interface GigabitEthernet1/0/42
description vlan 1
interface GigabitEthernet1/0/43
description vlan 1
interface GigabitEthernet1/0/44
description vlan 1
interface GigabitEthernet1/0/45
description vlan 1
interface GigabitEthernet1/0/46
description vlan 1
interface GigabitEthernet1/0/47
description vlan 1
interface GigabitEthernet1/0/48
description vlan 10
interface GigabitEthernet1/0/49
description port trunk
interface GigabitEthernet1/0/50
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
ip address 192.168.120.15 255.255.255.0
shutdown
interface Vlan10
ip address 172.10.5.15 255.255.248.0
no ip route-cache
ip http server
line con 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Switch#
Is this correct  ?
config t
interface Vlan1
no shutdown
interface Vlan10
no shutdown
Try ping locally
remote  ping
remote  ping
Post the results.
BB
Hi Balaji.bandi,
You are the best. I configure the instruction you send me and now is working. I saw that the 3750 don't create the vlan 10 until I setup a port with this vlan and that was the problem.
Thanks a lot
