Problems with load balancing, EIGRP
bej
I have 4 2501 routers and 2 computers. PC 1 is using Win XP and PC 2 Win 98. All routers are running IOS 2500-I-L, ver 12.1(2)T. When i send data from PC 2 to PC 1, traffic will not load balance across the 2 available paths. See diagram and configuration.
Show outputs on LabD
LabD#sh ip route
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
C 192.168.30.0/24 is directly connected, Loopback0
C 192.168.60.0/24 is directly connected, Loopback3
C 192.168.10.0/24 is directly connected, Serial1
C 192.168.40.0/24 is directly connected, Loopback1
172.16.0.0/24 is subnetted, 3 subnets
D 172.16.205.0 [90/4096000] via 192.168.10.15, 01:05:12, Serial1
[90/4224000] via 172.16.56.44, 01:05:12, Serial0
C 172.16.56.0 is directly connected, Serial0
D 172.16.31.0 [90/3584000] via 192.168.10.15, 01:05:12, Serial1
C 192.168.20.0/24 is directly connected, Ethernet0
10.0.0.0/24 is subnetted, 1 subnets
D 10.10.10.0 [90/3609600] via 192.168.10.15, 01:05:13, Serial1
[90/4249600] via 172.16.56.44, 01:05:13, Serial0
C 192.168.50.0/24 is directly connected, Loopback2
D 192.168.0.0/18 is a summary, 01:05:16, Null0
LabD#sh ip eigrp topo 10.10.10.0 255.255.255.0
IP-EIGRP topology entry for 10.10.10.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 3609600
Routing Descriptor Blocks:
192.168.10.15 (Serial1), from 192.168.10.15, Send flag is 0x0
Composite metric is (3609600/3097600), Route is Internal
Vector metric:
Minimum bandwidth is 1000 Kbit
Total delay is 41000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 2
172.16.56.44 (Serial0), from 172.16.56.44, Send flag is 0x0
Composite metric is (4249600/1817600), Route is Internal
Vector metric:
Minimum bandwidth is 800 Kbit
Load is 1/255
Minimum MTU is 1500
Hop count is 2
LabD#trace 10.10.10.1
Tracing the route to 10.10.10.1
1 192.168.10.15 4 msec
172.16.56.44 4 msec
2 172.16.205.1 8 msec
172.16.31.1 8 msec
172.16.205.1 8 msec
3 10.10.10.1 8 msec 4 msec 4 msec
Traceroute from PC 2:
tracert 10.10.10.1
1 3ms 3ms 3ms 192.168.20.179
2 4ms 4ms 5ms 172.16.56.44
3 6ms 6ms 6ms 172.16.205.1
4 5ms 5ms 5ms 10.10.10.1
6 Replies 6
bej
Here is the diagram
Here is the diagram
from your trace, you can see that the topology with the two paths is configured correctly. Possibly, you load-balancing scheme is per-destination. By default, on most Cisco routers, fast switching is enabled under interfaces. This is a demand caching scheme that does per-destination load-balancing. To set per-packet load-balancing, enable process switching (or disable fast switching) using the following commands:
Router# config t
Router(config)# interface Ethernet 0
Router(config-if)# no ip route-cache
Router(config-if)# ^Z
With per-packet load-balancing, packets are evenly distributed among the available links.
Can you try this on your router and see if it makes a difference ?
Georg
www.solutionfinders.nl
Take most be taken when using per-packet loadsharing. I have seen more issues caused by it than performance improvement. This is mostly related with TCP retransmissions that could be caused by out of sequence packets.
Hope this helps,
Thanks for your replies. I tried to use per-packet loadsharing, it did not make a difference. I am using Pcattcp to measure throughput from PC 2 to PC 1. With both interfaces on LabD up i get about 116KBytes/s, with interface serial 1 shutdown i get approx. 90 KBytes/s throughput. With load balancing i would expect approx. 1800kbits throughput to PC 1
This is exactly what I was referring to in my previous posting. When using TCP with per-packet loadsharing, you can't expect the throughput to double just because you have twice the bandwidth. If you use a sniffer trace, you will probably see alot of TCP retransmissions, which is not too good performancewise.
Hope this helps,
