Protocol Down in serial interface
abekeris
How can, in a serial interface (frame relay), the protocol go to the down state ?
We have two routers and it happened with the same serial interface in each router at the same time.
The routers are cisco 7304 with ios 12.2.20S
We fixed the problem with a reboot of both routers.
pflunkert
Level 4
Level 4
i found this:
CSCed70198
Release Notes
Symptom: The line protocol may go down.
Conditions: This symptom is observed when Frame Relay fragmentation is enabled
on the main interface.
Workaround: There is no workaround.
Fixed in: 12.2(24.2)S
But for further assistence we need the configuration and the exact hardware.
Peter
