QPM 3.0 Installation Problem
Hello colleagues,
I am having a problem installing QPM version3.0. For some reason, after the installation I do not see the program group, so I cannot start QPM. Has anybody experienced this problem ? What is the executable that starts QPM ? After the installation the CD says that it has finished installing the program, and I don´t get any error messages telling me that the installation has failed.
Thanks for your help in advance.
Georg
rmushtaq
Level 8
Level 8
You don't the folder under Start->Programs?. What kind of Windows box is this?. Prof, Server or Adv Server. Since QPM is a web based application, in order to access it, you need to point your web browser to the QPM Server via http://:1741
