08-08-2003 08:36 AM - edited 03-02-2019 09:27 AM
Here is my config for the 3550 I am using for my default router:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Switch
ip subnet-zero
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/1
switchport mode access
switchport access vlan 2
interface FastEthernet0/2
switchport access vlan 1
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no switchport
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address x.x.x.x x.x.x.x
interface Vlan2
ip classless
no ip http server
line con 0
line vty 5 15
I have both vlans plugged into my 4006 switch. Do i have to create vlan trunks on my switch to get this to work? can i just assign ip addresses to the ports if i do not want to use vlans? will that work?
thanks for any info
08-08-2003 05:07 PM
You don't need to use trunks if you have a single VLAN going across each link (i.e., if you have two links between the 3550 and 4006). You can give the interfaces themselves IP addresses on a 3550 rather than creating virtual VLAN interfaces, though you may need the EMI image to do so (I've never tried it with the SMI image).
08-11-2003 07:11 AM
Ok, I will look into that. thanks.
Jenn
08-11-2003 07:40 AM
You may need to turn ip routing on with statement "ip routing". I don't see it in your config.
If you put the ip addresses on the physical interface you need to turn off switching on those ports and make them routed ports with "no switchport".
08-11-2003 07:47 AM
Ok. My initial idea was to configure the 3550 with multiple subnets and assign to a port without using vlans. i am not ready to break up my network into vlans - (hardware)
if i assign an ip to the port with no switchport and ip routing, could this work on the existing vlan? right now, cisco had me assign a secondary IP to vlan1.
08-11-2003 12:55 PM
No, the ports set as routing ports would route data from the "int vlan" that the rest of the ports are in to the other device (cant remember what kind of switch it is). In other words the switch would have three ip addresses and one vlan1. That is not the way I would do it I was just pointing outthe need to shut off the switching IF you put an address on a port.
If you want two ip networks and one vlan then cisco's rec sounds good. All ports in one vlan with two addresses on the int vlan for those ports.
